1 - 3 of 3 Posts
Is there a way I can find the part number for the 99 dyna fuel tank vent fitting on my 99 Dyna Convertible? Mine will build up a lot of pressure in the tank then start pouring gas out of the carb and I think there was a recall on it. If I loosen up the gas cap the pressure coming out of it sounds like you cut a tire then the bike runs ok after that.
Jim
Thanks for the advice, I ordered a new vapor valve since they did have a problem with those causing gas to be forced out of the carb and a new gas cap just to be safe.
Jim
1 - 3 of 3 Posts
