1 - 7 of 7 Posts
I have a set of adjustable pushrods that came out of an evo. Will they work in a twin cam engine?
Thanks I’m debating on pulling cams to determine what’s in it and was going to cut stock pushrods if they would’ve worked because rocker boxes are real close to frame not sure if they’ll come off with engine in frame
The boxes come off real easy especially if you remove the tank first. You can remove the tank bolts and just block it up too.
Also a good time to clean the chrome.
I’ll try to pull them but they may be to close to frame. I’ll give it a try
The boxes slide out after the screws are removed they don't lift up and off.
1 - 7 of 7 Posts
