1 - 10 of 10 Posts
So I have a 06 Roadglide .. The old battery went south so I purchased another one and 2 months later it's dead again .. The symptoms it's been having :
When I'm riding I will see my voltage gauge drop down to 6-8 my battery light will come on including the engine light . I stil don't know but either when I accelerate or hit a bump it jumps back to 14 . But now it's really dead. I baught a tender aswell for the new battery .
Could it be the stator or regulator ? I tested both but maybe I diddnt do it correctly . Any advice would be helpful . Thanks gentleman
Kicking Rocks...
Check for loose connections inside the faring...
And
How did you test the charging system?
You have a short somewhere. Check for bare wire(s) rubbing against the frame or a ground somewhere. The fact that the voltage goes back to normal when you hit a bump of accellerate tells me you have a loose 12 volt wire somewhere hitting ground. The bump/ acellerate knocks it loose form the ground.
I sure will . What wires run inside the faring ? I checked it with a digital volt meter .. Stator and reg .. With ac and ohms
Kicking Rocks...
What was your standing voltage at battery not on or running?
What did you get at battery running @2000 rpm...
Black Velvet Elvis
Everything mentioned sounds helpful, I think you are on the right track in that the charging system is not functioning properly. I'll add that I personally find the service/electrical manuals to be very helpful and a worthwhile investment.
Check to see what codes are stored in the ECM. The procedure is a sticky in the electrical section.
Older Than Dirt
electrical/charging problems
Intermittent problems with the Voltage Regulator,
based on the similar problems I had. I think a lot of Bad stock
VR's out there. Had mine replaced with a Cycle Electric.
About 3x the cooling fins as a stocker.
Good Luck!
try checking the stator magnets they can come loose and shift (stops charging) hit another bump moves back and starts charging again i chased this problem for a week or two before i figured it out
1 - 10 of 10 Posts
