battery tender connector + headlights +gps install ?
2053 Views 7 Replies 5 Participants Last post by  amkaos
hi:
i have a 2004 heritage.
i wanna install gps on windshield. Leader Motorcycle GPS Windshield Mount (for Harley Davidson)
i would like to wire it from the headlight because it would be powered when key is on only.
i wanna connect it using a battery (sae) wiring harness ..
then a battery connector to usb converter from amazon.
Amazon.com: Battery Tender 081-0158 Black Quick Disconnect Plug with USB Charger: Automotive
then plug in cable from covverter to gps..
does this sound right?
thanx
1 - 8 of 8 Posts
It can certainly be done, but I'm not sure you want the extra load on the headlight circuit. Much better to find an accessory connection, or make one, using a relay driven off the light circuit, powered from the battery.
hi:
Amazon.com: Battery Tender 081-0069-6 Ring Terminal Harness with Black Fused 2-Pin Quick Disconnect Plug: Automotive
thanx
I don't see any problem with current draw, as the GPS is only a tiny amount.
:coffee:
Spotlights, could be accessory. Is there one on the other side? Get yourself a good manual, you'll love yourself for it.
What about this?
Amazon.com: Motorcycle Battery Hard Wire Charging Cable for Garmin Nuvi: GPS & Navigation
You could just run it all the way to your battery. It'll cost a little more but with less plugs to worry about disconnecting.
yes, there is one on right side, but missing the toggle..do you mean a owners manual or repair manual or something like that?..
for now im missing both..
owners manual at least would be handy..
What about this?
see that brick transformer?.. plus all the wire. i would rather keep wires close to where they are tapped in..plus, the battery tender converter is much smaller..thanx
1 - 8 of 8 Posts
