1 - 7 of 7 Posts
On a ride
Rinse dirt/grime off with water. Mild soap OK. Detail with Harley Gloss (Milwaukee denim recommended). The finish can scratch easy. If dusty, use Swiffer versus rubbing the dirt in.
Just passing thru
That picture is proof of your suggestions!
I will use widow cleaner with or without ammonia and a micro fiber rag when the dirt is not very heavy. Being sure to spray enough cleaner on as to float the dirt up. Dust with a dry micro fiber rag if it's just dusty. Soap and plenty of low pressure water for heavy road grime. I think I will get some of that Harley gloss and give it a try.
Ok Guys and Dolls any soap besides care wash will strip any wax you have on your sled and leave it unprotected.Windex will to the ammonia will strip it to and leave no protection against UV rays what so ever.Use a carwash soap remember its still clear coated but a flattining agent was added to give it the flat look its still the same paint as everyone elses just a little flatter.hope this helps you folks out.
1 - 7 of 7 Posts
