Status
Not open for further replies.
1 - 14 of 14 Posts
1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector. Other models will be under the seat.
2. To activate the diagnostic feature,follow these steps.
a. Create diagnostic test wire or use a female spade clip which will bridge the two terminals perfectly.
b. Install diagnostic test wire/clip across Terminals 1 and 2 on the data link connector, they are marked.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A “trip” consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diagnostics manual you're not going to know what they mean.
The code numbers are the numbers that appear in red.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault.
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Reactions: TXJax
Discussion Starter · #2 ·
2004-2008
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1600 EFI Module Processor Internal Error
20. P1270 TGS Validation Error
21. P2107 EFI Module Processor Internal Fault
22. P2122 TGS1 Low/Open
23. P2123 TGS1 High
24. P2127 TGS2 Low/Open
25. P2128 TGS2 High
26. P2138 TGS Correlation Error (Twist grip sensor)
27. P0120 TPS1 Range Error
28. P0220 TPS2 Range Error
29. P0122 TPS1 Low
30. P0123 TPS2 High/Open
31. P0222 TPS2 Low
32. P0223 TPS2 High/Open
33. P2135 TPS Correlation Error
34. P2119 EFI Motor Throttle Body Range Performance
35. P2100 EFI Motor Circuit Open
36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
37. P2102 EFI Motor Circuit Low
38. P2103 EFI Motor Circuit High
39. P2176 EFI Closed Position Not Learned
40. P1514 Air Flow Fault
41. P2105 EFI Forced engine shutdown
42. P1501 Jiffy Stand Sensor Low
43. P1502 Jiffy Stand Sensor High
44. P0572 Brake Switch Low
45. P0117 ET Sensor Low
46. P0118 ET Sensor High
47. P0112I AT Voltage Low
48. P0113I AT Voltage Open/High
49. P1351 Front Ignition Coil Driver Open/Low
50. P1354 Rear Ignition Coil Driver Open/Low
51. P1352 Front Ignition Coil Driver High/Shorted
52. P1355 Rear Ignition Coil Driver High/Shorted
53. P1357 Front Cylinder Combustion Intermittent
54. P1358 Rear Cylinder Combustion Intermittent
55. P0261 Front Injector Open/Low
56. P0263 Rear Injector Open/Low
57. P0262 Front Injector High
58. P0264 Rear Injector High
59. P0562 Battery Voltage Low
60. P0563 Battery Voltage High
61. P0501 VSS Sensor Low
62. P0502 VSS Sensor High/Open..
63. P1356 Rear Cylinder No Combustion
64. P1353 Front Cylnder No Combustion
65. P0444 Purge Solenoid Open/Low
66. P0445 Purge Solenoid High
67. P1475 Exhaust Actuation Position Error
68. P1477 Exhaust Actuator Open/Low
69. P1478 Exhaust Actuator Shorted/High
70. P0131 Front Oxygen Sensor Low
71. P0151 Rear Oxygen Sensor Low
72. P0132 Front Oxygen Sensor High
73. P0152 Rear Oxygen Sensor High
74. P0134 Front Oxygen Sensor Inactive
75. P0154 Rear Oxygen Sensor Inactive
76. P1510 EFI Limited Performance Mode
77. P1511 EFI Power Management Mode
78. P1512 EFI Forced Idle Mode
79. P0577 Cruise Control Input High
1. U1300 Serial Data Low
2. U1301 Serial Data High
3. U1016 Loss of ECM Serial Data
4. U1255 Serial Data Error
5. B1142 Smart Security System Internal Fault
6. B1135 Accelerometer Failed
7. B1136(HFSM) Accelerometer Tip Test Error
8. B1151 Bank Angle Sensor(BAS) Short to Ground
9. B1152 Bank Angle Sensor(BAS) Short to Battery
10. B1153 Bank Angle Sensor(BAS) High
11. B1154 Clutch Switch Input Short to Ground
12. B1155 Neutral Switch Input Short to Battery
13. B1134 Starter Output High
14. B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
15. B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
16. B1123(HFSM) Left Turn Output Short to Ground
17. B1124(HFSM) Right Turn Output Short to Ground
18. B1125(HFSM) Left Turn Output Short to Battery
19. B1126(HFSM) Right Turn Output Short to Battery
20. B1143(HFSM) Security Antenna Short to Ground
21. B1144(HFSM) Security Antenna Short to Battery
22. B1145(HFSM) Security Antenna Open
23. B0563 Battery Voltage High
24. B1131(HFSM) Alarm Output Low
25. B1132(HFSM) Alarm Output High
26. B1141(TSM) Ignition Switch Low/Open..
B1141(HFSM) Ignition Switch Low/Open
_____________
2010 DTC codes and Procedure
Odometer Self-Diagnostics DTCs (Diagnostic Trouble Codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM /HFSM, ECM and ABS DTCs. The Radio DTCs are retrieved through the radio and displayed on the radio display. See Table 2.
Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
Push the odometer reset button once and you will see the selection menu "PSSPtb" with the first P flashing.
Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t to b and back to P, etc.)
P --> ECM (Electronic Control Module [EFI])
S --> TSM/TSSM/HFSM (Turn Signal/ Turn Signal Security Module/ Hands-free Security Module)
SP --> speedometer
t --> tachometer
b --> ABS codes
To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTCs the code will be displayed or the word “none” will appear if there are no DTCs. Push the odometer reset button again to view additional codes if they exist.
Record the codes.
If DTCs are NOT to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' is displayed. Release the odometer reset button. Turn OFF the ignition switch. Perform a road test then shut your bike down. Recheck the DTC’s again by repeating steps 1 to 7. If the code is current it will reappear. Historic DTCs are stored for 50 ignition cycles before cleared. The security lamp will only indicate the existence of historic DTCs for two ignition cycles.
If DTCs are to be cleared for that module, press and hold the odometer reset button until 'clear' is displayed.
Turn Ignition switch to OFF to exit the diagnostic mode.
Always correct the serial data codes (DTC U1300, U1301, U1016, U1040, U1064, U1097, U1255) before resolving any other codes. DTC's are assigned priority numbers to determine the order in which they should be diagnosed. The lowest priority number DTC should be diagnosed first and then continue with the next lowest DTC.
Discussion Starter · #4 ·
Diagnostic Trouble Codes -DTCs-
DTC: B0562
FAULT CONDITION: Battery Voltage Low
SOLUTION: 3.6 DTC B0563, P0562, P0563
DTC: B0563
FAULT CONDITION: Battery Voltage High
PRIORITY ORDER: 138
DTC: B1004
FAULT CONDITION: Fuel Level Sending Unit Low
PRIORITY ORDER: 145
SOLUTION: 4.2 DTC B1004, B1005
DTC: B1005
FAULT CONDITION: Fuel Level Sending Unit High/Open
PRIORITY ORDER: 146
DTC: B1006
FAULT CONDITION: Accessory Line Overvoltage
PRIORITY ORDER: 143
SOLUTION: 3.7 DTC B1006, B1007
DTC: B1007
FAULT CONDITION: Ignition Line Overvoltage
PRIORITY ORDER: 142
DTC: B1008
FAULT CONDITION: Trip Odometer Reset Switch Closed
PRIORITY ORDER: 144
SOLUTION: 4.3 DTC B1008
DTC: B1121
FAULT CONDITION: Left Turn Output Fault
PRIORITY ORDER: 129
SOLUTION: 5.11 DTC B1121,B1122,B1123,B1124,B1125,B1126
DTC: B1122
FAULT CONDITION: Right Turn Output Fault
PRIORITY ORDER: 130
DTC: B1123
FAULT CONDITION: Left Turn Signal short-to-ground
PRIORITY ORDER: 131
DTC: B1124
FAULT CONDITION: Right Turn Signal short-to-ground
PRIORITY ORDER: 132
DTC: B1125
FAULT CONDITION: Left Turn Signal short-to-voltage
PRIORITY ORDER: 133
DTC: B1126
FAULT CONDITION: Right Turn Signal short-to-voltage
PRIORITY ORDER: 134
DTC: B1131
FAULT CONDITION: Alarm Output Low
PRIORITY ORDER: 139
SOLUTION: 5.18 DTC B1131,B1132
DTC: B1132
FAULT CONDITION: Alarm Output High
PRIORITY ORDER: 140
DTC: B1134
FAULT CONDITION: Starter Relay Output High
PRIORITY ORDER: 128
SOLUTION: 5.19 DTC B1134
DTC: B1135
FAULT CONDITION: Accelerometer Fault
PRIORITY ORDER: 23
SOLUTION: 5.12 DTC B1135,B1136,B1141,B1142
DTC: B1136
FAULT CONDITION: Accelerometer tip-over self-test fault
PRIORITY ORDER: 24
DTC: B1141
FAULT CONDITION: Ignition Switch open/low
PRIORITY ORDER: 141
DTC: B1142
FAULT CONDITION: Internal Fault
PRIORITY ORDER: 22
DTC: B1143
FAULT CONDITION: Security antenna short-to-ground
PRIORITY ORDER: 135
SOLUTION: 5.20 DTC B1143,B1144,B1145
Discussion Starter · #5 ·
DTC: B1144
FAULT CONDITION: Security antenna short-to-battery
PRIORITY ORDER: 136
DTC: B1145
FAULT CONDITION: Security antenna open
PRIORITY ORDER: 137
DTC: B1151
FAULT CONDITION: Sidecar BAS short to ground
PRIORITY ORDER: 25
SOLUTION: See Trike or Sidecar supp manual
DTC: B1152
FAULT CONDITION: Sidecar BAS short to battery
PRIORITY ORDER: 26
DTC: B1153
FAULT CONDITION: Sidecar BAS Out of Range
PRIORITY ORDER: 27
DTC: B1154
FAULT CONDITION: Clutch switch short-to-ground
PRIORITY ORDER: 28
SOLUTION: 5.21 DTC B1154,B1155
DTC: B1155
FAULT CONDITION: Neutral Switch short-to-ground
PRIORITY ORDER: 29
DTC: C0562
FAULT CONDITION: System Voltage Low
PRIORITY ORDER: 111
SOLUTION: 3.6 DTC B0563,P0562,P0563
DTC: C0563
FAULT CONDITION: System Voltage High
PRIORITY ORDER: 112
DTC: C1014
FAULT CONDITION: ECU internal solid state relay fault
PRIORITY ORDER: 105
SOLUTION: 7.15 DTC C1014,C1055-C1066,C1118,C1121
DTC: C1017
FAULT CONDITION: Pump Motor Power Circuit Open Fault
PRIORITY ORDER: 110
SOLUTION: 7.2 DTC C1017,C1018
DTC: C1018
FAULT CONDITION: Pump motor ground high resistance fault
PRIORITY ORDER: 109
DTC: C1021
FAULT CONDITION: Front wheel speed sensor always equals zero kph
PRIORITY ORDER: 115
SOLUTION: 7.3 DTC C1021,C1023
DTC: C1023
FAULT CONDITION: Rear wheel speed sensor always equals zero kph
PRIORITY ORDER: 116
Discussion Starter · #6 ·
DTC: C1025
FAULT CONDITION: Front wheel speed sensor signal intermittent
PRIORITY ORDER: 117
SOLUTION: 7.4 DTC C1025,C1027,C1206,C1208
DTC: C1027
FAULT CONDITION: Rear wheel speed sensor signal intermittent
PRIORITY ORDER: 118
DTC: C1032
FAULT CONDITION: Front wheel speed sensor circuit open or shorted
PRIORITY ORDER: 113
SOLUTION: 7.5 DTC C1032,C1034
DTC: C1034
FAULT CONDITION: Rear wheel speed sensor circuit open or shorted
PRIORITY ORDER: 114
DTC: C1042
FAULT CONDITION: Pump motor open
PRIORITY ORDER: 107
SOLUTION: 7.6 DTC C1042,C1043
DTC: C1043
FAULT CONDITION: Pump motor stalled
PRIORITY ORDER: 108
DTC: C1055
FAULT CONDITION: ECU internal fault
PRIORITY ORDER: 96
DTC: C1056
FAULT CONDITION: ECU internal fault - sold state relay shorted ON
PRIORITY ORDER: 97
DTC: C1057
FAULT CONDITION: ECU internal fault - solid state relay shorted to ground
PRIORITY ORDER: 98
DTC: C1061
FAULT CONDITION: ECU internal fault - front apply solenoid
PRIORITY ORDER: 99
DTC: C1062
FAULT CONDITION: ECU internal fault - front release solenoid
PRIORITY ORDER: 100
DTC: C1065
FAULT CONDITION: ECU internal fault - rear apply solenoid
PRIORITY ORDER: 101
DTC: C1066
FAULT CONDITION: ECU internal fault - rear release solenoid
PRIORITY ORDER: 102
DTC: C1094
FAULT CONDITION: Front brake switch always on
PRIORITY ORDER: 121
SOLUTION: 7.7 DTC C1094
DTC: C1095
FAULT CONDITION: Front brake switch open
PRIORITY ORDER: 122
SOLUTION: 7.8 DTC C1095
DTC: C1118
FAULT CONDITION: ECU internal fault - front apply solenoid correlation
PRIORITY ORDER: 103
DTC: C1121
FAULT CONDITION: ECU internal fault - rear apply solenoid correlation
PRIORITY ORDER: 104
DTC: C1151
FAULT CONDITION: Front wheel ABS release too long
PRIORITY ORDER: 126
SOLUTION: 7.9 DTC C1151
DTC: C1153
FAULT CONDITION: Rear wheel ABS release too long
PRIORITY ORDER: 127
SOLUTION: 7.10 DTC C1153
DTC: C1158
FAULT CONDITION: Calibration programming required
PRIORITY ORDER: 106
SOLUTION: 7.11 DTC C1158
DTC: C1206
FAULT CONDITION: Front wheel speed sensor frequency out of range
PRIORITY ORDER: 119
DTC: C1208
FAULT CONDITION: Rear wheel speed sensor frequency out of range
PRIORITY ORDER: 120
DTC: C1212
FAULT CONDITION: Front or Rear brake not applied with decel
PRIORITY ORDER: 125
SOLUTION: 7.12 DTC C1212
Discussion Starter · #7 ·
DTC: C1214
FAULT CONDITION: Rear brake switch always on
PRIORITY ORDER: 123
SOLUTION: 7.13 DTC C1214
DTC: C1216
FAULT CONDITION: Rear brake switch open
PRIORITY ORDER: 124
SOLUTION: 7.14 DTC C1216
DTC: P0031
FAULT CONDITION: O2 heater low/open
PRIORITY ORDER: 82
SOLUTION: 6.7 DTC P0031,P0032,P0131,P0132,P0134,P0151,P0152,P0154
DTC: P0032
FAULT CONDITION: O2 heater shorted/high
PRIORITY ORDER: 82
DTC: P0106
FAULT CONDITION: MAP Sensor Rate of Range Error
DTC: P0107
FAULT CONDITION: Map Sensor Open/Low
PRIORITY ORDER: 19
SOLUTION: 6.4 DTC P0107,P0108,P0112,P0113
DTC: P0108
FAULT CONDITION: Map Sensor High
PRIORITY ORDER: 20
DTC: P0112
FAULT CONDITION: IAT Sensor Voltage Low
PRIORITY ORDER: 58
DTC: P0113
FAULT CONDITION: IAT Sensor Voltage Open/High
PRIORITY ORDER: 59
DTC: P0117
FAULT CONDITION: ET Sensor Voltage Low
PRIORITY ORDER: 56
SOLUTION: 6.5 DTC P0117,P0118
DTC: P0118
FAULT CONDITION: ET Sensor Voltage Open/High
PRIORITY ORDER: 57
DTC: P0120
FAULT CONDITION: Throttle position sensor 1 range error
PRIORITY ORDER: 38
SOLUTION: 6.6 DTC P0120,P0122,P0123,P0220,P0222,P0223
DTC: P0122
FAULT CONDITION: TP Sensor Open/Low
PRIORITY ORDER: 40
DTC: P0123
FAULT CONDITION: TP Sensor High
PRIORITY ORDER: 41
DTC: P0131
FAULT CONDITION: Front O2 sensor low (lean)
PRIORITY ORDER: 84
DTC: P0132
FAULT CONDITION: Front O2 sensor high (rich)
PRIORITY ORDER: 86
DTC: P0134
FAULT CONDITION: Front O2 sensor open/not responding
PRIORITY ORDER: 88
DTC: P0151
FAULT CONDITION: Rear O2 sensor low (lean)
PRIORITY ORDER: 85
DTC: P0152
FAULT CONDITION: Rear O2 sensor high (rich)
PRIORITY ORDER: 87
DTC: P0154
FAULT CONDITION: Rear O2 sensor open/not responding
PRIORITY ORDER: 89
DTC: P0220
FAULT CONDITION: Throttle position sensor 2 range error
PRIORITY ORDER: 39
SOLUTION: 6.6 DTC P0120,p0122,P0123,P0220,P0222,P0223
DTC: P0222
FAULT CONDITION: Throttle position sensor 2 low/open
PRIORITY ORDER: 42
DTC: P0223
FAULT CONDITION: Throttle position sensor 2 high
PRIORITY ORDER: 43
DTC: P0261
FAULT CONDITION: Front Injector Open/Low
PRIORITY ORDER: 66
SOLUTION: 6.8 DTC P0261,P0262,P0263,P0264
DTC: P0262
FAULT CONDITION: Front Injector High
PRIORITY ORDER: 68
DTC: P0263
FAULT CONDITION: Rear Injector Open/Low
PRIORITY ORDER: 67
Discussion Starter · #8 ·
DTC: P0264
FAULT CONDITION: Rear Injector High
PRIORITY ORDER: 69
DTC: P0373
FAULT CONDITION: CKP Sensor Intermittent
PRIORITY ORDER: 18
SOLUTION: 6.9 DTC P0373,P0374
DTC: P0374
FAULT CONDITION: CKP Sensor Synch Error
PRIORITY ORDER: 21
DTC: P0444
FAULT CONDITION: Purge control open/low
PRIORITY ORDER: 77
SOLUTION: 6.10 DTC P0444,P0445
DTC: P0445
FAULT CONDITION: Purge control high
PRIORITY ORDER: 78
DTC: P0501
FAULT CONDITION: VSS Low
PRIORITY ORDER: 72
SOLUTION: 6.11 DTC P0501,P0502
DTC: P0502
FAULT CONDITION: VSS High/Open
PRIORITY ORDER: 73
DTC: P0505
FAULT CONDITION: Loss of Idle Sped Control
PRIORITY ORDER: 76
SOLUTION: 6.12 DTC P0505
DTC: P0562
PRIORITY ORDER: 70
DTC: P0563
PRIORITY ORDER: 71
SOLUTION: 3.6 BTC B0563,P0562,P0563
DTC: P0572
FAULT CONDITION: Brake switch low
PRIORITY ORDER: 55
SOLUTION: 6.13 DTC P0572
DTC: P0577
FAULT CONDITION: Cruise control input high
PRIORITY ORDER: 93
SOLUTION: 5.4 DTC P0577
DTC: P0602
FAULT CONDITION: Calibration Memory Error
DTC: P0603
FAULT CONDITION: ECM EEPROM Error
PRIORITY ORDER: 2
SOLUTION: 6.14 DTC P0603,P0605
DTC: P0604
FAULT CONDITION: RAM Failure
DTC: P0605
FAULT CONDITION: ECM Flash Error
PRIORITY ORDER: 1
DTC: P0607
FAULT CONDITION: Converter Error
DTC: P0641
FAULT CONDITION: 5V ref 1 out of range
PRIORITY ORDER: 16
SOLUTION: 6.15 DTC P0641,P0651
DTC: P0651
FAULT CONDITION: 5V ref 2 out of range
PRIORITY ORDER: 17
DTC: P0661
FAULT CONDITION: Intake solenoid low/open
PRIORITY ORDER: 48
DTC: P0662
FAULT CONDITION: Intake solenoid high/shorted
PRIORITY ORDER: 49
DTC: P1001
FAULT CONDITION: System Relay Coil Open/Low
PRIORITY ORDER: 12
SOLUTION: 6.16 DTC P1001,P1002,P1003,P1004
DTC: P1002
FAULT CONDITION: System relay Coil High/Shorted
PRIORITY ORDER: 11
DTC: P1003
FAULT CONDITION: System relay Contacts Open
PRIORITY ORDER: 10
DTC: P1004
FAULT CONDITION: System Relay Contacts Closed
PRIORITY ORDER: 13
DTC: P1009
FAULT CONDITION: Incorrect Password
PRIORITY ORDER: 14
SOLUTION: 6.17 DTC P1009,P1010
Discussion Starter · #9 ·
DTC: P1010
FAULT CONDITION: Missing Password
PRIORITY ORDER: 15
DTC: P1270
FAULT CONDITION: Twistgrip position sensor 2 A/D validation error
PRIORITY ORDER: 31
SOLUTION: 6.18 DTC P1270
DTC: P1351
FAULT CONDITION: Front Ignition Open/Low
PRIORITY ORDER: 60
SOLUTION: 6.19 DTC P1351,P1352,P1354,P1355
DTC: P1352
FAULT CONDITION: Front Ignition Coil High/Shorted
PRIORITY ORDER: 62
DTC: P1353
FAULT CONDITION: Front Cylinder No Combustion
PRIORITY ORDER: 75
SOLUTION: 6.20 DTC P1353,P1356,P1357,P1358
DTC: P1354
FAULT CONDITION: Rear Ignition Coil Open/Low
PRIORITY ORDER: 61
DTC: P1355
FAULT CONDITION: Rear Ignition Coil High/Shorted
PRIORITY ORDER: 63
DTC: P1356
FAULT CONDITION: Rear Cylinder No Combustion
PRIORITY ORDER: 74
DTC: P1357
FAULT CONDITION: Intermittent Secondary Front
PRIORITY ORDER: 64
DTC: P1358
FAULT CONDITION: Intermittent Secondary Rear
PRIORITY ORDER: 65
DTC: P1475
FAULT CONDITION: Exhaust position actuation error
PRIORITY ORDER: 79
SOLUTION: 6.21 DTC P1475,P1477,P1478
DTC: P1477
FAULT CONDITION: Exhaust actuator low/open
PRIORITY ORDER: 80
DTC: P1478
FAULT CONDITION: Exhaust actuator hight/shorted
PRIORITY ORDER: 81
DTC: P1501
FAULT CONDITION: JSS low
PRIORITY ORDER: 53
SOLUTION: 6.22 DTC P1501,P1502
DTC: P1502
FAULT CONDITION: JSS high
PRIORITY ORDER: 54
DTC: P1510
FAULT CONDITION: Throttle actuator control limited performance
PRIORITY ORDER: 90
SOLUTION: 6.23 DTC P1510,P1511,P1512
DTC: P1511
FAULT CONDITION: Throttle actuator limited power management mode
PRIORITY ORDER: 91
DTC: P1512
FAULT CONDITION: Throttle actuator control forced idle mode
PRIORITY ORDER: 92
DTC: P1514
FAULT CONDITION: Throttle actuator control system airflow fault
PRIORITY ORDER: 51
SOLUTION: 6.24 DTC P1514
DTC: P1600
FAULT CONDITION: TCA module - internal fault
PRIORITY ORDER: 30
SOLUTION: 6.25 DTC P1600
DTC: P1655
FAULT CONDITION: ACR solenoid low
PRIORITY ORDER: 94
SOLUTION: 6.26 DTC P1655,P1656
DTC: P1656
FAULT CONDITION: ACR solenoid high
PRIORITY ORDER: 95
DTC: P2100
FAULT CONDITION: Throttle actuator control motor circuit / open
PRIORITY ORDER: 46
SOLUTION: 6.27 DTC P2100,P2101,P2102,P2103
DTC: P2101
FAULT CONDITION: Throttle actuator control motor circuit - range error
PRIORITY ORDER: 47
DTC: P2102
FAULT CONDITION: Throttle actuator control motor circuit - low
PRIORITY ORDER: 48
DTC: P2103
FAULT CONDITION: Throttle actuator control motor circuit - high
PRIORITY ORDER: 49
DTC: P2105
FAULT CONDITION: Throttle actuator control system - forced engine shutdown
PRIORITY ORDER: 52
SOLUTION: 6.28 DTC P2105,P2107
DTC: P2107
FAULT CONDITION: Throttle actuator control module processor
PRIORITY ORDER: 32
DTC: P2119
FAULT CONDITION: Throttle actuator control system - throttle return error
PRIORITY ORDER: 45
SOLUTION: 6.29 DTC P2119
DTC: P2122
FAULT CONDITION: Twistgrip position sensor 1 low/open
PRIORITY ORDER: 33
SOLUTION: 6.30 DTC P2122,P2123,P2127,P2128
DTC: P2123
FAULT CONDITION: Twistgrip position sensor 1 high
PRIORITY ORDER: 34
DTC: P2127
FAULT CONDITION: Twistgrip position sensor 2 low/open
PRIORITY ORDER: 35
Discussion Starter · #10 ·
DTC: P2128
FAULT CONDITION: Twistgrip position sensor 2 high
PRIORITY ORDER: 36
DTC: P2135
FAULT CONDITION: Throttle position sensor correlation error
PRIORITY ORDER: 44
SOLUTION: 6.31 DTC P2135,P2138
DTC: P2138
FAULT CONDITION: Twistgrip position sensor correlation error
PRIORITY ORDER: 37
DTC: P2176
FAULT CONDITION: Throttle actuator control system - closed position not learned
PRIORITY ORDER: 50
SOLUTION: 6.32 DTC P2176
DTC: U1016
FAULT CONDITION: Loss of ECM Serial Data
PRIORITY ORDER: 7
SOLUTION: 2.3 DTC U1016,U1040,U1064,U1097,U1255
DTC: U1040
FAULT CONDITION: Loss of ABS serial data
PRIORITY ORDER: 8
DTC: U1064
FAULT CONDITION: Loss of TSM/TSSM/HFSM Serial Data
PRIORITY ORDER: 6
DTC: U1097
FAULT CONDITION: Loss of Speedometer Serial data
PRIORITY ORDER: 5
DTC: U1255
FAULT CONDITION: Missing response at module
PRIORITY ORDER: 9
DTC: U1300
FAULT CONDITION: Serial Data Low
PRIORITY ORDER: 3
SOLUTION: 2.4 DTC U1300,U3101 OR BUS ERROR
DTC: U1301
FAULT CONDITION: Serial Data Open/High
PRIORITY ORDER: 4
Radio Diagnostics:
The radio DTCs are retrieved through the radio and displayed on the radio display.
Press eject button to remove CD from unit.
While pressing and holding any two softkeys (buttons 1- 6), turn ignition switch "ON" until radio diagnostic display appears.
Discussion Starter · #11 ·
Radio Diagnostic Trouble Codes -RDTCs-
DTC: B0563
FAULT-SET CONDITION: t>=15 sec. V>= 16 Volts
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: Normal range for t>= 15 sec
DTC: B2006
FAULT CONDITION: Radio switch stuck or open
DTC: B2007
FAULT CONDITION: Handlebar switch shorted high
FAULT-SET CONDITION: Ignition ON after Ignition OFF for at least 10 sec., t=instantaneous
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: Normal range for t>=15 sec *
DTC: B2008
FAULT CONDITION: Handlebar switch shorted low
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: Normal range for t>=15 sec*
DTC: B2009
FAULT CONDITION: Handlebar switch stuck or open
DTC: B2010
FAULT CONDITION: Passenger switch shorted high
DTC: B2011
FAULT CONDITION: Passenger switch shorted low
DTC: B2012
FAULT CONDITION: Passenger switch stuck or open
DTC: B2016
FAULT CONDITION: Front speakers shorted
FAULT-SET CONDITION: R<1.5 Ohms tested once per ignition cycle R>1.0 Ohm when setup as line out ignition ON after Ignition OFF for at least 10 sec., t=instantaneous
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: R>1.5 Ohms tested once per ignition cycle
DTC: B2017
FAULT CONDITION: Front speakers open
FAULT-SET CONDITION: R>100 Ohms tested once per ignition cycle ignition ON after Ignition OFF for at least 10 sec., t=instantaneous
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: R>100 Ohms tested once per ignition cycle
DTC: B2018
FAULT CONDITION: Front speakers shorted to ground
DTC: B2019
FAULT CONDITION: Front speakers shorted to battery
DTC: B2020
FAULT CONDITION: Rear speakers shorted
DTC: B2021
FAULT CONDITION: Rear speakers open
FAULT-CLEAR CONDITION T=TIME; R=RESISTANCE: R<100 Ohms tested once per ignition cycle
DTC: B2022
FAULT CONDITION: Rear Speakers shorted to ground
DTC: B2023
FAULT CONDITION: Rear speakers shorted to battery
* Ignition ON after Ignition OFF for at least 10 seconds.
Calibration Data:
I = Intercom: 0=Disabled; 1=Enabled
J = J1850: 0=Disabled; 1=Enabled
V = Vehicle Speed Input: 0=Low; 1=High (1998-2005 Only)
H = Hardware Revision
ACR --> Automatic Compression Release
AFR --> Air Fuel Ratio
AIS --> Active Intake Selenoid
ATS --> Air Temperature Sensor
BAS --> Bank Angle Sensor
CAN --> Control Area Network
CCA --> Cold Cranking Amps
CCM --> Cruise Control Module
CKP --> Crank Position Sensor. The CKP generates an “AC signal” which is sent to the ECM where it is used to reference engine position (TDC) and speed. Home position established by taking readings off the 22 teeth on the alternator rotor.
DLC --> Data Link Connector
DTC --> Diagnostic Trouble Codes
ECM --> Electronic Control Module. (The Computer) Computes the spark advance for proper ignition timing and fuel control based on sensor inputs (from CKP, MAP & TP sensors) and controls the low-voltage circuits for the ignition coils and injectors. The dwell time for the ignition coil is also calculated in the microprocessor and is dependent upon battery voltage. The programmed dwell feature gives adequate spark at all speeds.
ECT --> Engine Coolant Temperature. Sensor also controls the cooling fan relay that provides 12 Vdc to the fans.
ECU --> Electronics Control unit
EFI --> Electronic Fuel Injection
EFP --> Electronic Fuel Pump
ET --> Engine Temperature sensor
FI --> Fuel Injectors
FPR --> Fuel Pressure regulator
EVAP --> Evaporative Emissions Control System
FPS --> Fuel Pressure Sensor
HCU --> Hydraulic Control Unit
H-DSSS --> Harley-Davidson Smart Security System
HFSM --> Hands-free Security Module
IAC --> Idle Air Control actuator
IAT --> Intake Air Temperature sensor
IC --> Instrument Cluster
ISS --> Ion Sensing System…detonation detection
JSS --> Jiffy Stand Sensor
MAP --> manifold Absolute Pressure sensor. The MAP sensor monitors the intake manifold pressure (vacuum) and sends the information to the ECM. The EMC then adjusts the spark and fuel-timing advance curves for optimum performance.
RCM --> Reverse Control Module
TCA --> Throttle Control Actuator
TGS --> Twist Grip Sensor
TMAP --> Intake air temperature/manifold absolute pressure
TPS --> Throttle Position Sensor
TSM/TSSM --> (Turn Signal/ Turn Signal Security Module)
VE --> Volume Efficiency
VSS --> Vehicle Speed Sensor. Used as an input for idle speed control
WSS --> Wheel Speed Sensor
07 - 09 DTC procedure
07 - 09 DTC's
Here's the listing of the diagnostic trouble codes (DTC codes). Some are similar to the 07 and previous years but there are some new codes too. Some even cross over into the 07 bikes and are not listed for the 07 bikes.
Flow chart for injector codes in pdf attachment at end of post.
SP = speedometer
T = tachometer
"No Rsp" (no response) will also appear if the run/off switch is in the off position when doing this procedure.
19. P1511 Throttle actuator control power management failure of throttle control actuator
20. P1600 EFI Module Processor Internal Error
21. P1270 TGS Validation Error
22. P2107 EFI Module Processor Internal Fault
23. P2101 throttle actuator control motor circuit range/performace error
24. P2122 TGS1 Low/Open
25. P2123 TGS1 High
26. P2127 TGS2 Low/Open
27. P2128 TGS2 High
28. P2138 TGS Correlation Error (Twist grip sensor)
29. P0120 TPS1 Range Error
30. P0220 TPS2 Range Error
31. P0122 TPS1 Low
32. P0123 TPS2 High/Open
33. P0222 TPS2 Low
34. P0223 TPS2 High/Open
35. P2135 TPS Correlation Error
36. P2119 EFI Motor Throttle Body Range Performance
37. P2100 EFI Motor Circuit Open
38. P2101 EFI Motor Circuit Range Performance (Actuation Error)
39. P2102 EFI Motor Circuit Low
40. P2103 EFI Motor Circuit High
41. P2176 EFI Closed Position Not Learned
42. P1514 Air Flow Fault
43. P2105 EFI Forced engine shutdown
44. P1501 Jiffy Stand Sensor Low
45. P1502 Jiffy Stand Sensor High
46. P0572 Brake Switch Low
47. P0117 ET Sensor Low
48. P0118 ET Sensor High
49. P0112I AT Voltage Low
50. P0113I AT Voltage Open/High
51. P1351 Front Ignition Coil Driver Open/Low
52. P1354 Rear Ignition Coil Driver Open/Low
53. P1352 Front Ignition Coil Driver High/Shorted
54. P1355 Rear Ignition Coil Driver High/Shorted
55. P1357 Front Cylinder Combustion Intermittent
56. P1358 Rear Cylinder Combustion Intermittent
57. P0261 Front Injector Open/Low
58. P0263 Rear Injector Open/Low
59. P0262 Front Injector High
60. P0264 Rear Injector High
61. P0562 Battery Voltage Low
62. P0563 Battery Voltage High
63. P0501 VSS Sensor Low
64. P0502 VSS Sensor High/Open..
65. P1356 Rear Cylinder No Combustion
66. P1353 Front Cylnder No Combustion
67. P0444 Purge Solenoid Open/Low
68. P0445 Purge Solenoid High
69. P1475 Exhaust Actuation Position Error
70. P1477 Exhaust Actuator Open/Low
71. P1478 Exhaust Actuator Shorted/High
72. P0131 Front Oxygen Sensor Low
73. P0151 Rear Oxygen Sensor Low
74. P0132 Front Oxygen Sensor High
75. P0152 Rear Oxygen Sensor High
76. P0134 Front Oxygen Sensor Inactive
77. P0154 Rear Oxygen Sensor Inactive.
78. P1510 EFI Limited Performance Mode
79. P1511 EFI Power Management Mode
80. P1512 EFI Forced Idle Mode
81. P0577 Cruise Control Input High
2. U1301Serial Data High
3. U1016Loss of ECM Serial Data
4. U1255Serial Data Error
5. B1142Smart Security System Internal Fault
6. B1135Accelerometer Failed
7. B1136(HFSM)Accelerometer Tip Test Error
8. B1151Bank Angle Sensor(BAS) Short to Ground
9. B1152Bank Angle Sensor(BAS) Short to Battery
10. B1153Bank Angle Sensor(BAS) High
11. B1154Clutch Switch Input Short to Ground
12. B1155Neutral Switch Input Short to Battery
13. B1134Starter Output High
14. B1121(TSM)Left Turn Output Fault
B1121(HFSM)Left Turn Output Open
15. B1122(TSM)Right Turn Output Fault
B1122(HFSM)Right Turn Output Open
16. B1123(HFSM)Left Turn Output Short to Ground
17. B1124(HFSM)Right Turn Output Short to Ground
18. B1125(HFSM)Left Turn Output Short to Battery
19. B1126(HFSM)Right Turn Output Short to Battery
20. B1143(HFSM)Security Antenna Short to Ground
21. B1144(HFSM)Security Antenna Short to Battery
22. B1145(HFSM)Security Antenna Open
23. B0563Battery Voltage High.
24. B1131(HFSM)Alarm Output Low
25. B1132(HFSM)Alarm Output High
26. B1141(TSM)Ignition Switch Low/Open
B1141(HFSM)Ignition Switch Low/Open
The following came from the ABS section of the 2008 Electrical Diagnostics manual- hopefully close enough until something better comes available...
C0562 Device voltage low
C0563 System voltage high
C1014 ECU internal fault
C1017 Pump motor power circuit open fault
C1018 Pump motor ground high resistance fault
C1021 Front wheel speed sensor equals 0
C1023 Rear wheel speed sensor equals 0
C1025 Front wheel speed signal intermittent
C1027 Rear wheel speed signal intermittent
C1032 Front wheel speed sensor circuit open or shorted
C1034 Rear wheel speed sensor circuit open or shorted
C1042 Pump motor open
C1043 Pump motor stalled
C1055 ECU internal fault
C1056 ECU internal fault
C1057 ECU internal fault
C1061 ECU internal fault
C1062 ECU internal fault
C1065 ECU internal fault
C1066 ECU internal fault
C1094 Front brake switch always on
C1095 Front brake switch open
C1118 ECU internal fault
C1121 ECU internal fault
C1151 Front wheel release too long
C1153 Rear wheel release too long
C1158 Calibration programming required
C1206 Wheel speed sensor frequency out of range
C1208 Wheel speed sensor frequency out of range
C1212 Front or rear brake not applied with decel
C1214 Rear brake switch always on
C1216 Rear brake switch open
U1300 Serial data low
U1301 Serial data open/high
1 - 14 of 14 Posts
Status
