1 - 13 of 13 Posts
Hey Guys
I have a 2003 FLHTC with 90k KM. Bike has 95 kit,cams,Rineheart true duals, high flow air filter, and SERT. It was dino tuned a six years ago.
I have noticed that its running really rough when its cold. I didn't think too much of it because it went away when it warmed up. The past few days its been running rough when its warmed up. Tonight I pulled the plugs and they had a white dusty build up on them. This tells me the old girls running lean. My question is what might cause this to happen out of the blue.
On a side note I have been using the new shell high test gas and at the beginning of the season i ran some fuel treatment through it (4 tanks of gas have been ran through since)
Thanks for any help!!
Vacuum leak?
Intake seals are leaking. When they first start to leak, as the motor warms up, they will seal off . After some time they will no longer seal off as motor warms up.
Fits with what you have posted .
Indecisive Member
+1 for that
Spray some carb cleaner around all of your intake (just not into the intake) and if your rpm's rise then you have a leak. It is a fairly simple job to replace them as well.
Discussion Starter · #5 ·
Ill spray some throttle body cleaner around it and see if it affects the idle to test the intake leak theory. How would I be able to test for a vacuum leak?
IAC might be dirty. Try squirting some carb cleaner into the IAC pintle hole and cycle the ignition several times to free things up.
Indecisive Member
Glad you got it running right.
Cleaned mine today, spayed & used a cleaning probe in there. All kinds of black stuff in there. Idle goes bad sometimes in hot weather, sounds like its running rich. Runs fine today.
1 - 13 of 13 Posts
