I recently purchased a set of HD spotlights (flood lights) with attached turn signals for a 2008 custom built softail. From the minute I cut the wires from the turn signals that were attached to the handle bars, the left began blinking continuously and I cannot get it to shut off. I purchased a new turn signal module before doing ANY research. Turns out, that did not fix anything. After research and some discussion, I am pretty sure I have lost a very important ground wire. The original turn signals that were on the handle bars had two wires (red & black) and the turn signal itself being connected to the metal handle bars acted as a (or THE) ground. The turn signals on the spot light bar has three wires (purple, blue & black). I can get the right turn signal to operate without issue. These turn signals also act as running lights, and like I said, I can get the right to operate without issue. The left, I can get operating except I cannot get it to shut off. I can go on and on about the variations of wiring I have tried, but we'll save that for later. I'm hoping I'm just missing something obvious and someone will have the solutions to my issue maybe through experience. Any advice is helpful. I'm going to research the turn signal module wiring code just for knowledge until I get some answers back. Thanks guys!
Jason
Jason
