Was it very difficult to bleed the brakes? I bled the brakes on an older model volkswagon beetle, pump the brakes, hold them, while another person loosens the tap/nut, tighten and do that a few times to get all the air out. What is the process for the brakes on the motorcycle? Is this explained in the service manual?Mine was $13, (Dealer close out on the brake line, measured to fit for my bike) and $10 for Silicone brake fluid. (DOT-5)
Took me about 30 minutes to swap. Bleeding it was a trick.......:nananana Almost took me 35 minutes......:stir
Let me know if you can tell a difference in performance. I have a 2008 Dyna Super Glide and I have put about 2300 miles on it so far since July 3rd. Bought the bike and what better way to celebrate Independence Day!My bike is in the shop right now having all the cables switched over to HD's Diamondback Stainless Cables. Originally started with the front and rear break but figured it wouldn't look right so I got them for the clutch and Throttle Idle as well. Can't wait to see how much of a difference there is with the Stainless Cables.
