You can do the change but your ABS light will be on until the dealer turns it off.
What I don't know is if the ABS just plain doesn't work during this time.
I have changed the bars on my SG with abs and had to get a new brake line. Pulled the main fuse before I started work and didn't put it back in until I was completely done. No abs light and abs works fine.I have also seen posts on here where as the bars have been changed and new lines were needed so changing the brake fluid was needed and there was no light after the bleeding was done guess its a hit or miss weather a dealer would be needed.
thanks for the info I'll try that, not changing any brake line so there should be no air in the lines, just changing fluid.I have changed the bars on my SG with abs and had to get a new brake line. Pulled the main fuse before I started work and didn't put it back in until I was completely done. No abs light and abs works fine.
