Hope this isn't too dumb of a question, but here goes. I have a 90 Sporty and changed the rear brakes recently. I bought DOT 4 while there and assumed there was DOT 3 or 4 was in there. You can mix Dot 3 and 4 from what I understand, but not DOT 5 (synthetic).
After I changed brakes, I blead. Refilled the master cylinder up and put the lid on. That is when I noticed the lid said use DOT 5 only. At that point I got some tubing and sucked out all the fluid and blead the rest. Refilled with DOT 5 like it said. The fluid that came out initially seemed to be brown, but the 5 is purpleish. Also when I blead the 5 it seemed to kind of bead on top on the 4 that was previously blead in the drain bucket, so I assume it was initially 3 or 4. The brakes do work just fine as is but am concerned with traces of 3/4. With the 5 I have had no problems for the last week and a half or so, and brakes work perfect now.
So now what??? Should I drain again, clean out the lines with something and refill with 4? Will this system gum up now that has traces of 3/4? The rear brakes work great currently but did I screw up big time?
I will replace the front as well soon. The fluid in the master is brownish so I assume 3 or 4, but need to make sure.
