1 - 7 of 7 Posts
Hey guys,
I've had :issues" with my brakes since day one. I've got an '04 FLSTC and I've never been satisfied with my braking performance. It stops OK and no sponginess but I just think it could be better. I've put a new rear MC kit in it, rebuilt front and rear calipers but still think it could be better when comparing to the wife's '12 FLSTN. Anyway this go 'round I noticed the brake light wasn't working when I applied the rear brakes so i replaced the switch and figured while I was at it, I'd change out the fluid completely. I bought a bleeder tool with the small hand pump and tested on the wife's bike. It worked like a charm and I was completely done in 20 min so I figured mine would be a breeze. First issue was I seem to have a leaky bleeder valve on the front caliper. It was constantly sucking air and it didn't seem like it was bleeding the line properly. Can you replace those bleeders? I finally got an OK lever after using almost a whole bottle of fluid so I figured I'd find out about replacing that bleeder before getting into that too far. The back seemed to be going ok but of course I ran out of fluid and it's time to go to work so I figured tomorrow is another day. any suggestions on the front caliper? shore of replacing the whole thing any suggestions? I'm ready to trash the HD system and go totally aftermarket!
they unscrew all the way and are replaceable, you can change the forks and hub and put duel disc like the touring bikes
I did solve the issue, seems the hose was letting air in around the bleeder valve. I manually bled the brakes and no air! I'm back in the wind with good pedal and lever pressure. I can really tell the difference with the new fluid in the lines.
Keep on Ridin’
Bleeding brakes can be frustrating. Glad you got it sorted out!
NevRL8
glad i found this thread!
i've never been happy with the front brake on my '07 FLSTC, but switching from a bike with dual front calipers (electraglide) there is gonna be some difference. after a near rear-end collision i decided i have to do something. have any of you switched out the stock HD front calipers for aftermarket with more pistons? say, a jaybrake with the six piston setup (3 per side)?
i know you can swap out the forks for a dual rotor setup but it's expensive and i'd like to try the bigger calipers IF THEY HELP.
anybody?
Discussion Starter · #7 ·
Sleepy have you ever changed the fluid? By taking my caliper apart and cleaning it and changing the fluid the difference was amazing. I did the wife's '12 Deluxe the same way and it totally improved the stopping power and firmness of the lever pull.
1 - 7 of 7 Posts
