pick up an 05 sporty for wife and the hand brake does not illuminate the brake light is this norm? if not then what should i check first?
help
The housing next to the M/S has a little tit from the brake switch sticking out. Look and see if it is lined up with the brake lever .brake peddle works fine. ran diagnostic everything shows good dont really know if that checks switches
Not sure what you mean by "running diagnostics" but the front brake light circuit is a simple switch and wiring to bulb. Switches are prone to failure. Trance wire from switch to first connector and short the two wires at the connector, if bulb lights, switch is bad.
Master cylinder is what he meant. There's a switch in housing beside it.
