My brother just burnt the clutch on his Wide Glide. What would cause this? Would this be a defect covered under warranty? Was he just hot rodding it too much? he said he wasin 5th doing about 55mph gunned it to 70mph then shifted to 6th. then the engine seemed to rev to high. he down shifted, down shifted, until 1st gear. Then bike wouldn't shift out of 1st. Dealer said burnt clutch. Any help?
A few things come to mind other than abuse, which is the first thing ANY dealer will claim, as clutch discs are considered "wearable, non-warranty" items, like brake pads, and tires.
1. The clutch could have been adjusted too tight. You have 2 adjustments for a clutch:
a) the pushrod screw/adjuster in the center of the clutch basket that adjusts for clutch preload, (at the pushrod that goes through the trans, and releases the clutch plates when pressure is applied to the clutch lever.) This is always adjusted first, with the cable end play adjustment fully UN-adjusted.
b)Cable end play adjuster on the cable, at the left side of most bikes, (I believe the right side on the FL models) that adjusts the slack in the cable, determining release and re-engagement of the clutch when pulling the lever.
As the clutch wears, (and it will faster, if you speed shift or pull out hard/fast repeatedly) the fiber covered discs become thinner, and less slack in the adjustment becomes an issue, as it's the same as almost "riding" your clutch when the adjustment reaches a certain level.
Enough wear and the clutch will begin to slip, creating heat and more wear.
2.) Hot Rodding. Wear is one thing, but constantly overheating a clutch causes rapid wear on the plates, warpage of fiber and metal friction plates. In extreme cases, it can ffect and weaken the Diaphram Spring, or the "pressure plate" if you will, that holds constant tension on your clutch plates, and prevents them from slipping.
Secondly, heat also degrades the primary fluid, resulting in an inability to keep the clutch plates cooler, resulting in a quicker failure.
I'd highly recommend any bike that had a failed clutch resulting in slippage, (outside normal wear) should receive a new clutch diaphram as well, as it may be related to the failure, or possibly damaged from the failure.
