Change the rotor out to the 45 amp one. The stator is the same part number.
There are 50 amp rotors and stators on the market also.
Change the rotor out to the 45 amp one. The stator is the same part number.05 Electra glide classic about how many amps does a stock alternator push out and to get 45 amps do I replace the rotor or the stator
No I haven't done the load test yet I'm going there soon. ThanksJust curious if this is in relationship to your post HERE?
It`s your bike. You are entitled to throw all the money at it you wish to.
I plan on upgrading my charging system down the road myself.
But if this is related then am curious if you had the battery load tested. Checked the connections.
And the questions regarding the compression, which you said you felt may be a problem, were never answered.
Inquiring minds, at least mine, would like to know.
