1 - 2 of 2 Posts
2007 FLHRC
Hey all
Im brand new to the forum and have what i see as a major issue with my bike. I have a 2007 ROAD KING Classic with a power commander 3, stage 1 air system and vance and hines true duals. I have codes of p0118 and p0373. This happened after a Joe Florida LED light system was installed. The fuel tank was loosened for light install and the fuel line from tank to intake manifold broke. I replaced that with an HD part. Also 3 of the LED wires were run under the tank. At the same time the dash panel was removed to clean corroded ignition contacts on the plug. I should say that the 3 wires were removed from the plastic clip for the ignition. I am worried that maybe I didnt put them back in the correct order??? Anyway after the lights were installed and tested the bike was started and immediately threw a check engine light. Also the bike just doesnt seem to run as should. I tried clearing the codes threw the instrument cluster but they come right back. I also unplugged the power commander to check for differences but there were none. I am stumped. I am currently pulled the gas tank to check for any possible wiring issues. Any and all help would be much appreciated! !! Thanks!
Mississippi Cajun
Since you're not confident that you replaced those 3 wires correctly, that'd be the place I would begin looking.
1 - 2 of 2 Posts
