1 - 11 of 11 Posts
i was charging the battery on my 2004 nighttrain,came back everything dead.battery has 12 volts. where is the circuit breaker? any ideas on the problem?
Circuit breaker is just ahead of the plastic guard below the rear fender.
is this by the battery
It is on the other side (behind) the battery box.
You need to remove the plastic splash guard to access the circuit breaker.
After you clean it up, dielectric grease will prevent that from happening again . :)
:biker:
You should put a 30 amp back in there.
If the circuit breaker is being tripped, you need to find where the short is.
1 - 11 of 11 Posts
