1 - 20 of 25 Posts
I have a 15 road king with a 110 build engine, Im getting clutch slippage at higher rpms in fifth gear, I adjusted it and have also added heavy duty clutch spring, Looks like Im ready for a good clutch and wanted some recommendations, nothing real grabby.
You have the reduced effort clutch ramps which reduce clutch disengagement travel. That in conjunction with the extra plate kit will make finding neutral difficult at a stop unless you shut off engine.
Discussion Starter #6
After I installed clutch spring I had installed a different clutch ramp to make the pull easier.
Yup, those wont work with the extra plate kit.
Discussion Starter #17
Found a dealer here in pa advertising Aim VP026-95 iv for 242.95 with free shipping would it be the same or a japenese knockoff?
Discussion Starter #18
Ordered Aim today should have wed or Thursday, that should keep me going, I will probably install new clutch plates this winter.
1 - 20 of 25 Posts
