1 - 8 of 8 Posts
I need to add some fluid to my clutch master cyclinder on my relatively new to me 09 saxon. How can I tell if the fluid presently in the master clylinder is DOT 3 or 4 or DOT 5 as I know i cannot mix 3/4 with 5. Is there a way to tell or should i just add some DOT4 as i do not know what is in there presently? Running a hydraulic clutch with a primo rivera 6 speed RHS tranny thanks
Look in manual or contact mfgr.
Discussion Starter · #4 ·
Do not have a manual and do not know who made the cylinder however I have found through other sources two methods of checking what type of fluid it is. 1) take a few drops from the master cylinder and drop them in a glass of water and mix. If it mixes with the water then it is DOT3/4 and if it does mix then DOT5
2) mix some of the fluid rom the cylindr with some new DOT3/4 or DOT5. whichever one it mixes with is the type you have in the cylinder
Good luck.
Wayward Son
Those test methods actually do make sense.
Reread the last part of number 1. If it mixes its DOT3/4 and if it mixes it DOT5. That tells us a lot.
1 - 8 of 8 Posts
