If the clutch grabs off the bars, and you have the proper end play in the cable, than the basket ISN't adjusted correctly, or something is wrong with the ball/ramp assembly in the side cover.
The ball/ramp isn't throwing the actuator far enough to get the clutch to disengage.
Make sure there's not a ball missing (3) and in the primary case.
Adjust clutch to tension, then only a 1/2 turn out.
