1 - 5 of 5 Posts
I am at a crossroads to replace my original clutch. It's an 07 FLHRC with 82K on her, yes there all bona fide miles. Would like to hear from any one on any suggestions in a replacement? Screaming Eagle or something different. Any suggestions would be helpful.
If you got 82k out of the stock, why not go back with it?
The higher performance clutches are designed for use with higher performance motors. If you aren't putting the extra stress on the clutch, you'll never see any benefit from a "better" one.
Sent from Motorcycle.com App
The motor was recently bumped up to an 103 from the stock 96inch
Unless you bumped the compression and did the heads also, I'd think the stock clutch would be fine.
Stock clutch with the SE spring would handle the 103ci just fine, IMO. I think the SE comp sprocket assy. would be a good upgrade also.
1 - 5 of 5 Posts
