1 - 5 of 5 Posts
trying to get a read if I have high compression pistons. I have no contact with PO. 02 twin cam 88, probably been cammed. I did a compression check on a cold bike, no oil squirted into the cylinders. got 140 pounds in each? Thoughts? Thanks everyone.
Not high comp. from that number.
Squirt oil in cylinders, hold throttle wide open and crank for 10 revs. on each cylinder. Post the #s.
IMO you can't tell if you have high compression pistons by doing a compression test. Too many factors of cam specs. involved. Not counting conditions of valves rings, etc.
Agreed ^
I would also do it with a warm motor...u can have 10:1 pistons but have a big enough cam to drop cranking psi low to make u think u have flat tops or even dished pistons...get a bore scope
That has less compression than an untouched engine, probably over-cammed, unless another issue.
Scott
1 - 5 of 5 Posts
