Only on shovels and pans. Aluminum heads and cast jugs. More expansion on evo with aluminum jugs and heads.
Only on shovels and pans. Aluminum heads and cast jugs. More expansion on evo with aluminum jugs and heads.Considering going to copper head gaskets on my evo 80 but I have no experience with them...ive heard good things but ive also heard you need to check the torque often...where as on a normal 3 plate you torque once and just double check after a few heat cycles and leave it after that...
Any one with good experience let me know pros n cons
+1!!Cometic is THE gasket to use.
