On a Road King? If it's got one, I ain't smart enough to find it.No you'll need the radio. Yours is gone ?
Yea, I saw this thread and remembered how easy it is to check everything on my FJR and started looking for ways to do the same on the RK.Oh I see now, you aren't the OP. You have a RK !
Had something similar happen on my '07 Road King, except it was back brake only. The pressure sensor switch that activates the lights went bad and the brake lights were not coming on and the cruise would not disengage when applying the rear brake. I too had a semi close call on an interstate...which is how I found out about it. I changed the pressure switch and haven't had a problem since.
another thing to look at is your brake fluid level; it might be affecting the disengagement.
Something else you could have done is just shut of the cruise with the switch on the bars.
BTW, where you live, doesn't merging traffic have to yield to traffic already in a lane? Those cars should have adjusted their speed to merge safely. I know you don't want to die for your right of way, but it seems people now think you are required to let them over.
