1 - 2 of 2 Posts
I have a 08 RK stock motor and will be installing the Monster Ovals and some type of high flo AC. I see that there is a new PC out and do not know what the difference is.
Also I read on another site that the 08/09 models came with the stage 1 download already installed does anyone know if this was a fact? From what I read these were installed to help with the heat issues?
If this is true would anyone know if it would be safe to run the monstar ovals with the stock AC?
Discussion Starter #2
Thanks for the info!!!!!!
J
The PCIII-USB-EX is primarilly for California owners, since the PCIII is no longer "allowed" to be used for road use in CA, the land of emissions.
It uses the standard map for the low end and then the PC-EX only takes over at the higher rpms.
No adjustability for the low rpms ranges.
If you don't live in CA, I can't see buying it. It's a legal thing.....
As for the stage-1 MAP thing.....can't say. Call your dealer.......
1 - 2 of 2 Posts
