Have a 22 fxlrst. Got my oil change at 1.2k miles have 3200 on it now. These dipsticks and checking the oil are confusing the hell out of me. Not sure if I checked it right but I took it out for a ride. Let it idle upright for a minutes. Shut it off then put it on kickstand and checked.
Photo is what I got. Should I add some oil in it or is it good? Also anyone know if it's full synthetic. I assume its 20w-50.
Image Screenshot-20221009-133216 hosted in ImgBB
ibb.co
You checked it correctly. The idea is you want the bike at full "Normal operating temp" before checking.
The photo you posted indicates it's near the "Add 1 full quart" mark. So technically, No you don't "need" to add oil now.
However, i prefer to keep the oil at the midpoint between full and add. So i would add a little less than 1/2 quart.
But, that's just my opinion.
What oil is in it?
Well that depends on where or who changed the oil.
If you had the service done at a HD stealership, they would have put the Screamin Eagle synthetic in.
At a indi shop, that would depend on the shop.
Either way you can service it up with either the Screamin Eagle or Mobile V-Twin 20-50.
By law the oils must be compatible to intermix.
