1 - 19 of 19 Posts
On a ride
Good question. I'm sure years and miles are factors, and the web also notes keeping the tension right is helpful. Saw a post recently from someone with over 100,000 miles on their bike. A rock broke the belt at 45,000 miles, and the replacement has worked fine since. Maybe others have a reference on this?
Administrator
57k on my first belt on the FLHT, now at 107k, this belt appears fine.
FWIW,
I've read that a tight belt is a sure recipe for a short life. Better to be a little loose than a little tight.
Ride on, ride well.
Doug
"I took the one less traveled by,
And that has made all the difference."
I had to replace on the road king around 42k.. Only because a rock had gone through it..
My bike is a 2000, and I think the replacement for it was an even better belt.. they have improved over the years..
I would reccomend a close inspection, looking for unusual wear and cracks, or a defect, hole or something..
Other wise I say ride.....:ride
PS.. The shop even said they have seen holes in the middle( not on the edge ) of the web still running.. But I don't reccomend it..
I break stuff.
If properly adjusted, they will easily go 50-75k... and often much further.
Seems like the only problems are foreign objects and improper adjustment.
Not having to dink around with chain lube/adjustments rocks!
I know of a Karata replacement belt that is going on its 18th year on a Low Rider. The stock belt caught a rock in New Mexico and punched a hole in it. The replacement got me through England, Belgium, Holland, Luxembourg, Germany, from Wichita KS -> Los Angeles, and from Wichita KS <-> Sturgis.
Im running an 89 FLH with 210,000 klms,BURNOUTS,drag racing, ang generally hard riding over 20 years.The last 40000 klms with a good sized chunk missing from the outer edge but the belt's still going strong.Dammm near indestructable.
1 - 19 of 19 Posts
