Trusting the safeties will work when it has to be disengaged quickly. Giving up control even with the safeties.Getting used to how?
Ever had that problem with cruise in your car? Probably won't ever have it with your bike, either. Don't worry so much. If it ever jams on you just head towards the grassy side of the road and jump off.Trusting the safeties will work when it has to be disengaged quickly. Giving up control even with the safeties.
Webbie68,Trusting the safeties will work when it has to be disengaged quickly. Giving up control even with the safeties.
Need to change my profile 03 UltraWebbie68,
I just noticed in your profile that you have a 2002 fatboy. If this is the bike you still have it does not have cruise control, it only has a throttle lock. A throttle lock gets set just tight enough to put a slight drag on it so it can still be easily be turned to the Idle position. Throttle locks do not really have any safety features.
