1 - 11 of 11 Posts
Guitarslinger
yep, that should work.
What is the purpose of the different colored materials?
I think it is just the color of the foam that he decided to use. It looks like he used the blue foam to build up on top of the white foam, which, I believe, is the existing foam from the stock seat.
Nice work, BTW. Did you do the upholstery as well?
MPG'S? Who gives a
The "blue" foam is called "chip foam" It's used as carpet under pading too. Density is the difference.
Alot of the Appolstry guys carve the foam with elect knives like what ya use for Turkeys...
Fatboy2011
Discussion Starter #9
it was attached in layers and build the shape and strength needed .
The blue foam was than covered by the black top material , same shape as the original as seen in the picture . it works great and cost all total $80 .
MPG'S? Who gives a
The blue foam is not Chip !!!!! you maybe mean Cheap (even your mother thoung is English and not mine . but it was attached in layers and build the shape and strength needed . no need to be negative .
Nothing "negative" was said Ilan. Practice your engliish a bit more my friend because you misread pretty much everything.
I know you meant to write "Mother tongue".
Ps. Foam that is made with "small pieces of different density and types of foam IS called "chip foam" in America.
Fatboy2011
Discussion Starter #11
Thank you . appologize if I miss understood you . lets enjoy riding :)
1 - 11 of 11 Posts
