1 - 11 of 11 Posts
So I recently purchased my first HD. A 2011 Dyna Super Glide. It vibrates alot when riding it and Ive asked a few people if they think its normal that it should vibrate that much with mixed responses. However none of these people own similar bike so who knows. Im trying to find a way to share a video of bike doing it. Does anyone have any thoughts on this please?
Check the motor mounts and any loose critical fasteners, how many miles ?
Reactions: WiSeNhEiMeR
There is a difference between idle "shake" and riding "vibration" in Dyna's. It's normal for the engine to jump around at idle, but there should be very minimal vibrations felt in the bars or pegs when riding above 2,000 rpm. If the exhaust is touching the frame anywhere other than the two ports and transmission mounting point, you will get vibration. A loose front motor mount can also be a culprit.
Discussion Starter · #4 ·
789416
this shows the shake on handle bars when idling.
Paintball Vehicle Games Cameras & optics Glass
0
Thanks, the vibration is still an issue when riding to the point my hands go numb from the vibration and the mirrors jitter around so much you cant really see shit in them properly.
View attachment 789416 this shows the shake on handle bars when idling. View attachment 789416 0
As others have said, the motor mounts could be an issue. As far as feeling the vibes through the handlebar, foot pegs etc. Do you have the original rubber foot pegs and hand grips? Or were they replaced with something else? My 2008 came with really sharp looking pegs and grips, but they did a very poor job of isolating vibration. I put the stock rubber foot pegs back on and that pretty much solved the problem for me. The fact that your mirrors are blurring, assuming they're stock, and in the stock location, does indicate you've got something else going on. At least that's what it says to me.
Sent from my Pixel 3a using Tapatalk
Discussion Starter · #8 ·
789522
789524
Hi. Check your tires and rims are, ok for balance and weighted correctly also check the wheel bearings are ok.
The motor is rubbered mounted and should not vibrate so you may need to check the mounts...
1 - 11 of 11 Posts
