1 - 5 of 5 Posts
Does anyone know if there is ignition-ON electrical terminal that I can hook up a oil cooling fan? My bike is a 2007 Softail Deluxe. I don’t own a service manual yet. I will not cut into wires to attach this.
I been searching and haven’t found anything. I will take pictures and post.
Thanks
Under the seat there's an accessory connector, it's got a dummy plug in it.
I found one that is always hot. I am looking for one that when key is to run, power will be on. I will check it again. Thanks
The accy connector is hot only with the ignition on. It should be attached to the frame at the left rear battery area, not to be confused with a similar connector, data link to the ECM.
I will look for it ths week end. Have to work late and put some OT. I did find one that was hot all the time just in front of the battery.
Thanks for the quick reply.
1 - 5 of 5 Posts
