1 - 4 of 4 Posts
Having serious electrical issues started out with no blinkers occasional lights and now I replace the ignition switch but I can drive for a little while and then turn off and then it won't turn back on I have a 2001 Electra Glide Ultra Classic
Super Moderator
Loose connection around the gooseneck? Try to see if symptoms vary if handle bars are one extreme to the other. Sometimes just resetting all the connections can chase away a gremlin.
GO through all your electrical connections, starting with the battery and make sure all are clean AND TIGHT. Most complaints like this are loose connections to the battery. Check both ends
1 - 4 of 4 Posts
