1 - 6 of 6 Posts
I have a 01 ultra classic. At idle bike charges between 10/12 on gauge with my voyage tester attached to battery it is showing 13/14.23. At crusing speeds the gauge on dash goes to 16 check eng lite comes on and it will slowly go down till bike dies. Is this a volt reg prob or a stator prob. I am a mechanic been wrenching on Harley's for years but have no exp on anything twin cam. Due to the cost of parts to repair I cannot replace both at same time or I would do so. Trying to pin point stator or reg. Battery test good at 400 cca as well.
I can't help you but it is a custom to go to the new members section first and introduce yourself first before asking questions. Someone will come along that can help. Welcome from NY.
Kicking Rocks...
Check the electrical section... There is a sticky on charging system check
Over charging is a symptom of a faulty regulator. It's best to test the stator for shorts and opens before throwing parts at the bike tho.
Harley Rider
Sounds like a regulator if it's jumping to 16.
1 - 6 of 6 Posts
