1 - 4 of 4 Posts
Good morning. I have a quick question and it will seem a bit elementary no doubt to many of you. I h a 2015 Street 750 . Want to install engine guards. There is a plastic cover over the engine in front. I have the service manual but it make no mention o o to remove it so that I can install install engine guards. The instructions with with engine guards shows I already removed. I it just attached with grommets? I can I just gently pull it off? Any advice advice advice advice appreciated!
Alice
Since I don't know of any engine cover, I'll assume you're talking about the radiator shroud? If so there are a couple of bolts at the bottom of it.
Post some pictures if that's not what you are talking about.
1 - 4 of 4 Posts
