1 - 7 of 7 Posts
COB
Hmmm.... if my bores mic out am I ok to just hone and replace rings? I have always replaced the pistons too, but do I need to ? I can mic them too, correct?
But is it a good idea? The bike has 20k on it. Air cooled Yamaha XS-650.
On that same note, I don't have access to a valve spring compression tester. On a low performance engine like the XS-650 can I just measure spring height?
This is kind new, coz I have in the past only taken engines apart that I was going to throw a lot of parts at. Not much of a mechanic, but fairly competent parts changer guy.
And I have two manuals, so I have all the tables of measurements.
Any ideas for a cheap freshen up are appreciated.
With only 20k miles, I can't see that there would be anything wrong with the springs. I don't think I would personally worry about those if you are going with stock cams.
Again with the pistons on a 20k motor, if the bores and pistons mike out ok, I say run em.
Just my 2c.
COB
Hmm..... I think I will take it apart to see what is inside.
COB
I hope you never uttered these words at work.
COB
Discussion Starter #6
Other than cleaning up the carbon deposits, do I need to scuff up the pistons or just put them in as-is?
1 - 7 of 7 Posts
