1 - 8 of 8 Posts
Softails & Choppers
:bikerguy:Hey guys! I have a slightly messaged t.c. 95 c.i. engine that produces104 h.p. and 106 torque. Runs great but I use Mobil1 synthetic 20w-50. No engine sounds at all when cold, but develops a light ticking soung and I can't pinpoint where it's coming from when the oil is at full operating temp. Has anybody else used the same oil and hear more engine sounds?
Yup....Mobil here also..I did notice when I changed to full synth a little bit more ticking but not a lot.
i used syn 3 for the longest time but have since changed to klotz full syn...not as much noise compared to syn 3, also changed out the primary and trans to klots...they make a few different oils you can use, 1 is for both primay and trans the others are primary only and trans only, i use the primary only and trans only, shifting is alot smoother then with other oils and neutral is easily found
Hit it she goes boom
Add Amsoil to the list, more noise too..
1 - 8 of 8 Posts
