1 - 10 of 10 Posts
Ok check this out in any gear steady on throttle at 2000 rpm I get a vibration? TC 88 stage 1 carb 02 Electra Glide no wierd noises Im hopeing it just that kinda dead or flat spot in the throtle?
At 2000 rpm you are pretty much lugging the engine.
It may be that the purpose of you life is to serve as a warning to others.
What happens if you tach it up a bit - to say like 2300-2500 rpms?
Village Idiot
That vibration gets fixed by making the tach needle move higher. Should smooth right out...
Sent from Motorcycle.com App
I also prefer to run higher than 2,000 rpm. Just for grins, look at your front motor mount. Oil and time makes the rubber collapse and it may cause a vibration.
Discussion Starter #8
Well I found my problem one missing and one loose motor mount bolt didnt catch the missing one cause it was under the oil filter.
Glad you found the problem.
1 - 10 of 10 Posts
