What's up guys, I have a 02 fatboy with the 95in kit, SE heads, Gear driven cams, I got the bike used, it's super clean, ran great, but was a little lean, (it would ping a little on a hard pull sometimes). So I rejetted the carb. The bike had a 45 pilot, 190 main and a dyno jet needle. I went with a 48 pilot, 195 main, and the cv performance N65(sportster) needle. The bike runs great, no more pinging under full throttle, putting around seems ok too, but when the bike is idling and you crack the throttle it just seems to rev a little slower? I guess is the word than it did before. Just not as responsive as it was down low before. Any ideas?
Also if I turn the air/fuel screw in the bike does die down so I don't think the pilot is to big, I have the screw just a little over 2 turns out.
Thanks in advance!
Thanks in advance!
