1 - 20 of 22 Posts
Bike: 2014 XL1200T
Mileage: 5000
Problem: when I turn on the bike all of the lights turn on , on the speedo, momentarily per usual but when I start it, it kind of struggles and the transmission light illuminates for a few seconds then turns off.
This has only been happening for a week or two and I'm pretty sure this not supposed to happen. The bike was purchased used about 4 months ago. Anyone know what the problem could be?
Wow did the prev owner use an impact wrench on that?
Yeah get that replaced.
Reactions: JTJ
If it was up to me they would replace it, but you'll have to ask them. It obviously was worked on by a not-well-trained monkey, maybe one of theirs. Did you get any kind of warranty?
Our local dealer gives a one year warranty on used bikes. I don't know if that's a MOCO thing or just Temecula H.D.
It's definitely worth rolling in for a visit.
i have a 2003 lowrider 100year while riding or ideling motor shutsdown and i have to wait untill it cools to start
That sounds like a vapor lock problem... Have you had any work done on the carburetor? I'm questioning my memory, that is an Evo motor, correct? I would clear the fuel tank, put fresh Premium in with some Sea Foam. But most importantly clean the carb and the fuel strainer.
weird member
1997 Softail Custom (FXSTC)
2003 is a TC.
Evo run was 1984-1999 (end year Dyna and Touring 1998, softail 1999, 2000 CVO FXR4)
Reactions: 1/2 Ton
2003 is a TC.
Thanks Kyle. I got that one totally wrong! But it still sounds like that old "vapor lock" problem from years ago... That's another problem with getting old...some chit just blends together.....:rolleyes:
Reactions: JTJ
Bike: 2014 XL1200T
Mileage: 5000
Sounds like you’re gonna need a new battery
Flats where its at
after u get the new batt remember to always put kickstand on rubber or wood so u dont ground the system out = dead battery............... jus sayin
craze, Earth ground and Battery ground are NOT the same thing....Just sayin
Reactions: Kainam
You forgot to put a smiley face after your post so people would know you are joking...
You`re joking, right?
Reactions: 1/2 Ton
You mean satellites dont need to run a ground wire to earth to work???
Reactions: 1/2 Ton
1 - 20 of 22 Posts
