Hi All,
My bike (2017 Heritage) developed a leak in one of the hard oil lines going from the sump to the engine crankcase. I've learned that the hard lines have a tendency to crack due to vibration. Sort of makes sense, given that the lines are attached to the frame-mounted oil tank on one end and the vibrating engine on the other end. I'm wondering if there is a retrofit kit available that uses flexible lines instead, at least for the lower portion. This would allow the line to flex with the engine and hopefully avoid cracking. Any ideas? My bike has been repaired with OEM parts, but if it happened once in 25,000 miles it will happen again, probably...
