Can I wire my fog lights (new kit) directly to the Siren switch? It isn't used anymore and would be a more direct route than using the wireharness that came with the light kit. I also have a black toggle switch on LH side. Can I use this one? I think I understand the reason for the elaborate wiring harness is to connect it in such a way that the fog lights only work when the headlight is on lowbeam. I am trying to use existing wiring / switch instead of adding more to the bike. what are the drawbacks of this? thanks. David
