1 - 10 of 10 Posts
Hi All,
I have a 2000 Road King- it is missing the fork lock key.
I have the ignition key, but it will not turn the lock regardless of where the forks are located.
Thanks.
Wayne
Poser Member # 99
Try spraying lock pin from the bottom with some P B blaster . They rust or stick from not being used and you have to turn your forks probally to the left. Some times you have to fine the sweet spot for the pin to set into Should be Keyed same as Ignition. Good Luck
Senile Member
Yeah, greese her up, let her sit over night and see if you can work it in the morning.
Tough call though, scew with it and it may lock and not unlock.
1 - 10 of 10 Posts
