I've been a big advocate of the FP3 tuner for a while , I've felt it's a good product and it is however it seems there may some not so good short comings with the Auto-tune feature.
This was post by GMR Performance on their FB page :
Vance & Hines FuelPak 3 (FP3)
It's time for a honest conversation about this tuner shall we?
A few years ago it was launched as the first tuner capable of "auto tuning" your motorcycle via a free App on your cell phone.
It's no secret Smart phones are here to stay. You are probably using one now. You're in constant contact with your loved ones with it. With the FP3 you can be in contact with your other love; Your Harley!
Man it's pure marketing genius! It can flash your ECM with tune that somebody, somewhere developed with some bike and then you can magically turn the auto-tune fiction... I mean function on and tune your beloved companion to perfect by yourself! For FREE!! What can go wrong? How awesome!
SUCKER- You've just been made a target market!
Now for the truth.
-Can you choose from hundreds of tunes? Yes
-You can do it by yourself using your smartphone?
Yes
-it's capable of "Auto Tuning" using your factory 02 o2 sensors?
Yes
"Auto Tuning".... I know you're now thinking "why does he always put "Auto Tuning" in quotations?
"Auto Tuning" isn't really doing what you've been marketed to believe. What it's actually doing is changing the Desired target air:fuel ratio to what your factory closed loop system (means active 02 sensors) are capable or reading and sets the entire fuel map into a very lean 14.4 target
-Why is this a bad idea?
Because your ignition timing map was created using air/fuel ratios of 12.5 to 14.6.
-Why should that matter?
Timing is everything!
-All exhaust systems are not created equally
O2 sensors on many aftermarket exhaust systems are placed in areas easily accessible for YOU or your mechanic to get to but may not be in a area of where the actual exhaust gases are flowing inside of the pipe. Think of how a river flows for this. The exhaust gasses much like flowing water do not like to go around corners.
02 sensors would totally screw up the looks of your exhaust system if placed where they should go. Instead manufactures hide them in places that are often times on inside bends of a exhaust Header where the exhaust gasses aren't even touching them! Another false reading will be guaranteed by a 02 sensor bung that is so long that the sensor can't reach into the flow of exhaust gasses. O2 sensor adapters will do the same thing as too long of bung. This gives the 02 sensor a false lean reading and in turn overcompensates the fuel adjustment actually causing your engine to run stinking rich.
You've all heard a bike pulling up to stop light popping or backfiring like crazy right? Most of the time the bike is running a very loud, zero restriction exhaust system. The popping is actually caused by exhaust reversion (pulling raw fuel from the cam overlap where the exhaust valve is still open while the intake valve is just starting to open) Reversion popping is caused from from raw fuel coming in contact with the hot exhaust pipe causing a pop when the fuel is ignited within the pipe.
Guess what? The 02 sensors just received a whole bunch of false readings from all that popping and banging.
Well engineered exhaust systems give the exhaust a pulse. Think of s heart monitor pulse rate that only moves in one direction, out the tail pipe.
Poor exhaust systems that are wide open do not give the exhaust system a good pulse so they flat-line and allow the exhaust to travel in and out of the tail pipe. (Exhaust reversion is amplified with these system)
Guess what? 02 sensors in wide open exhaust systems are worthless because of all the false readings they get.
Here is a common complaint I hear almost everyday.
Prospective customer- "My bike runs great in some areas with the FP3 and like shit in others"
Dyno Guy- let me guess, at cruise speed it runs great and full throttle it's crap right?
Prospective Customer- Exactly! How did you know that?
Dyno Guy- I'm a Jonny Carson, Karnak fan.
Prospective customer- Crickets
Dyno Guy- that's because the auto tune function was set to read 14.4 at high engine load areas and is running lean or your 02 sensors have been receiving false lean readings and you're running very rich in some high load areas.
Prospective customer- ok, so what do you recommend I do?
Dyno Guy- Sounds like you need a dyno tune and a different tuning system
Prospective Customer- I just paid $450 for this one! Why can't you use the FP3?
Dyno Guy- because I have no way to enter my data into your tables without going through hundreds of of cells manually.
Prospective Customer- man this sucks, I should of just paid you guys to tune this thing right the first time instead of buying this thing.
Dyno Guys- yeah, I hear you. Would you like to schedule a tune?
Prospective customer- Yeah, we better.
This conversation is played out all too often. I really wish Vance & Hines would offer a interface that professionals could use to tune the FP3's. If they did, they'd have a great product. Until that day, I might go into the pet rock FP3 paperweight business with all the useless FP3's I've collected.
Vance & Hines! Please do your current customers and mine the service they deserve with a PC interface for professionals!!!
Some food for thought anyway .
Now for the truth.
Yes
Yes
