1 - 5 of 5 Posts
I own a 2013 Limited. I have about 13,000 miles on it. The other day I noticed that my from brake Master cylinder had a small leak around the gasket. I tightened the cover screws some. I did not synch it down to where gasket was squeezed out and deformed. Still very small leak. It will leak enough to leave a trail to the outside edge of lever bracket. Anyone have issues with gasket. Cheap enough to fix, however. Just wondering what is going on. Thanks for any response.
Change it quick because the DOT4 will eat the paint.
If it hasn't already. Wash everything down with water, water cuts the DOT4.
Discussion Starter · #5 ·
Absolutely, Schmidtys. Thanks. No noticeable depletion in reservoir, as far as naked eye can see anyway. Time for monthly water-wash this afternoon. That will get fixed right away.
1 - 5 of 5 Posts
