Clean caliper pistons. You likely pushed them back dirty. That prevents a good lever. There's a sticky in the tech area. They should be cleaned once a year or 5k. When you push them back dirty, the dirt prevents them from coming out of the bore easily and evenly.
Take of calipers and pads again. Gently pump caliper pistons out half way, two at a time. Clean. Use a toothbrush and brake clean. Do others. Do other side. Reassemble. Wala.
The partial splitting of the caliper was an f-up, but not related to your issue.
