1 - 6 of 6 Posts
I have a 97 Electra Glide Classic. Today I noticed a gas leak. It's right at the coupling below the hex nut that goes in the tank. Does th entire fuel injection line need to be replaced or can I just replace the o'ring. I've researched were people have just replace the o'ring.
Here is a youtube video that I saw saying you can just replace the o'ring. https://www.youtube.com/watch?v=3Owzb-MVqkM
If the entire line need to be replace would I be able to just replace the part coming out of the gas tank with this (Spectre 5946 Fuel Fitting Fuel Fitting 90 Degree (Chrome) 3/8" NPT to 3/8" Barb, Spectre Limited Lifetime warranty - JCWhitney) and then connect the current injection line hose with some new hose?
Any help would be great
Replace the O rings ...it'll be fine .. :)
That 90 degree elbow wouldn't work. The line has to have one way pressure. Without it, the fuel pressure would always be working against your pump.
1 - 6 of 6 Posts
