1 - 15 of 15 Posts
Hi to all
today i got a problem, fuel was leaking heavily out of the fuel supply line fitting under the tank at the chrome sleeve.
i have to stop the bike because my pants are getting wet, not a good feeling with a heated engine and 90°F outside.
i called AAA they send a tow truck, now i am at home and looked for the fuel line which i removed, seems to have no problem, but i will install a new one, just in case ( 11 years old ).
in the chrome fitting which comes out of the fuel tank i saw ( with a mirror ) there is an O-ring inside.
is it a problem just to remove this small o-ring with a dentists instrument or so and put in a new one ,or do i have to uninstall and replace the whole Chrome fitting part from the tank?
thanks in advance for your help, and have a great week
Ralph
There's TWO o-rings inside that fitting. One is farther up in the tip. The one that leaks most of thr time is the lower one you can see. There's a kit to replace them including the tool. Kinda pricey considering strong wire with a hook works. If you want the O-ring, you can match one up at any auto parts store or ask the HD parts guy for part #11323.
Harley Check Valve Rebuild Kit and instruction video by Fuel Tool:
EBay repair kit:
http://pages.ebay.com/motors/link/?nav=item.view&id=301048025299
Sent from Motorcycle.com App
Reactions: TXJax
Hi Dave63
i ordered the Tool Kit and O.Ring set, should arrive end of week, will see if it works.
thanks for your help.i will post it when i am finished
Ralph
Fuel tool
Hi to all
i got my fuel tool MC400, it worked, but the first hook broke after the first attempt.
Ralph
Is it just me or ?? ... when he plugged in the connector the fuel seems to leak a bit just before the video end....
On the loose
I got mine out with a pick , it was hard and brittle ,I really had to dig it out of the groove, came out in little pieces. Got an O-ring from John Deere for $1.30 , coated it along with the male end O-ring in silicone grease before I installed it , still seals 2 years later.
On the loose
Being his bike is an 03 they might issue a tech bulletin or maybe already do have but I'd think a recall is unlikely.
You can update your own for $1.30 > John Deere part # R26286 is the right size = 10mm X 14mm X 2mm is made of Nitril so it's fuel safe.
Harley will only sell the whole assembly for about $ 125 .
My bad . Didn't see what year bike he was having trouble with !:sleep
I replace my O-ring on that quick release fitting yesterday as a matter of fact. I used 90° pick and a mirror with a headlamp on my head. Whole job literally took less than 5 minutes. I wasn't sure if I had the right size o-ring in my shop so I texted one of my HD mechanic friends and you told me it's the exact same o-ring that we use for our drain plugs. Put just a little tiny bit of o-ring grease on the new o-ring and the male fitting, put it back together, leak is gone!
Can you indulge me with the O-ring size to get for the lower?
Mine started leaking at the weekend on a 2010 FLHTCU and will start there with a replacement.
With the virus lockdown, only way to get anything is online here in the U.K.
Thanks.
Sent from my iPad using Tapatalk
These are the "O" Rings I bought a few years ago for my drain plugs. The "O" Ring I used that day was from a HD oil change kit. After doing research on this here forum, I found out that this is the correct/same size "O" Ring for the drain plugs. The fact that I was able to use it for my fuel QD was a lucky tip from an Indy friend and it worked just fine. YMMV....... HD makes it some sort of secret on the QD "O" Ring size and won't sell anything like a rebuild kit for it in an effort to make you buy the whole QD fitting/hose. At least that's my guess.
1 - 15 of 15 Posts
