1 - 2 of 2 Posts
Just bought one for my 2014 wideglide. Can I use it for my stock set up before I get my pipes and air cleaner. I did put cycle shack mufflers on it while I have been deciding which pipes to buy.
CRSO
Assuming you're using the app for Bluetooth cnnectivity, open it and go to Demo Mode; it allows you to look thru available V&H maps.
Text Font Screenshot Technology Sky
It appears there are maps for the Dyna with stock pipe and intakes for both the 96 and 103 Engines.
You should be fine...of course, if you are reluctant to do this you can still use the FP3 to monitor engine data without any changes to your ECU until you get your new add-ons.
When you DO remap, the FP3 saves your stock (factory) map so you can revert to it.
1 - 2 of 2 Posts
