Fuelpak and cam upgrade??
3079 Views 2 Replies 3 Participants Last post by  Hillsidecycleco
guy's I currently have a 2008 dyna stock 96" motor,HD heavy air intake set up,with shortshot's,and v/h fuelpak... getting ready to do the Andrews 48h cam upgrade with upgraded inner bearings... has anyone had success with cam upgrade and using the fuelpak... vance and hines tech support told me to use fp-1497 map... I know the fuelpak is not a top choice when doing a cam upgrade?? but has any members had success with similar setup?? would appreciate some input on this..
thank you
1 - 3 of 3 Posts
You can try the fuel pack since you already have it but I would suspect that in the long run you will end up going with a dedicated tuner and a dyno to get the full performance you are shooting for.
It'll "work", but there are better.
Scott
1 - 3 of 3 Posts
