From the Vance and Hines web site
"Before making additional changes for camshaft(s) and/or engine modifications, you must first flash a base map onto the bike. Then, go to ‘View/Edit Maps’ and select the map you want to edit. Under the ‘Air and Fuel’ section you will find ‘Camshafts’. Under the ‘General’ section you will find other critical tables such as displacement, injector size, and rev limit. These tables can also be found in the ‘Map Optimization’ menu from the ‘Main Menu’."
